June 10, 20233 yr Hello, i want sync to vaults to sync with the same iCloud account. One vault for my stuff and one for my daughter.But when I connect in the settings the second vault to iCloud it overwrites the stuff in the first vault with the stuff from the second vault. Michels.
June 12, 20233 yr Hi @michelos Welcome to the Enpass Forums. When using multiple vaults in Enpass, each vault must be connected to a separate cloud account for syncing. It is not possible to connect more than one vault with the same cloud account. However, if you are using WebDAV/OwnCloud, sync with multiple vaults by defining separate paths/folders for each vault.
