July 4, 20233 yr Is there a way to turn off this auto fill or to delete them all so I can restart from new
July 5, 20233 yr Hi @Theliltank4901 Based on the screenshot you provided, it appears that you are using the iOS version of the app. To disable the autofill feature on your iOS device, please follow these steps- Go to the Settings app on your device, then select Passwords. Tap AutoFill Passwords. Toggle off the AutoFill Passwords option.
