July 31, 20224 yr Hello! Apologies if my request is duplicated, but I haven't found anything suitable at the moment. I am using enpass v6.8.2 for macOS and I would like to manually arrange/move the categories in the sidebar. At the moment I can only select or deselect them. Regards, Oliver
August 1, 20224 yr Hi @masterkw, Welcome to the Enpass community. The input you provided is very valuable to me, and I appreciate you taking the time to do so. Please be assured that I have taken note of your suggestion and forwarded it to the relevant team for further consideration. #SI-3016
August 1, 20224 yr Author Hi Gulshan, thank you for reply, I will stay tuned! With my iOS devices (iPhone/iPad) it is possible, but.... ...if you do so on one device there's no sync to the other one, certainly not with the iMac. I have to rearrange it manually on every device. Edited August 3, 20224 yr by masterkw
July 9, 20233 yr A. There must be an option to add more categories in the left-most tool bar A. B. There must be an option to sort by categories in B. So if we chose ALL in the toll bar, we can sort thrn all by categries.
