July 13, 20233 yr Enpass güvenli değil. Güvenli olmadığı kadar hem açık kaynak değil hemde yedekleme kısmında bir tane dahi açık kaynak bir depolama bile yok.
July 14, 20233 yr Hi @gurco21 With Enpass, your data is fully encrypted with 256-bit AES with 100,000 rounds of PBKDF2-HMAC-SHA512 using the open-source encryption engine SQLCipher. This provides you with advanced protection against brute force and side channel attacks. You can learn more about security with Enpass by referring to this link. Regarding Enpass not being open source, the same is being discussed in the below-mentioned forum -
