July 21, 20233 yr Hello, I don't see an option to change the display order of categories (especially not by dragging). Is something like that in the plan?
July 24, 20233 yr Hi @ljubacanoa In Enpass, you can customize which Categories appear in Enpass, and can even create your own. Depending on the device you are using, I would suggest checking this link to know more about it.
July 24, 20233 yr Author 2 hours ago, Abhishek Dewan said: In Enpass, you can customize which Categories appear in Enpass, and can even create your own. Depending on the device you are using, I would suggest checking this link to know more about it. Hello, Sorry, but I didn't asked that. I asked about REORDER the category items. Now they appear (from top to bottom) as first, some default categories, and after that in alphabetical order.
July 25, 20233 yr Hi @ljubacanoa Kindly provide the version of the Enpass app and the operating system you're currently using. Once you share this information, I'll be more than happy to assist you by checking the details and offering you the appropriate steps.
July 26, 20233 yr Hi @ljubacanoa We sincerely appreciate you for providing the requested details. After thorough discussions with our development team, we are considering the possibility of incorporating this feature request in upcoming Enpass releases, even though we haven't received any specific timeline for its implementation. Your support and patience mean a lot to us, and we are grateful for your valuable input. #SI-3016
