May 10, 20188 yr Hi there, I am quite happy with your product. There is only one occasion where it does not fill in information properly. See attached copy. When I click enpass to have it fill in the information, it fills the left column (which is wrong) because it is for the first registration only. It should, however, fill in the right hand column where it asks "Already registered?" Have you made any progress when it comes to wifi-sync?? Thanks Friedrich
May 28, 20188 yr I've come across this issue a lot lately as well. In my case the password is filled in the correct field. But the email field is filled in the "Registration"-Part of the page instead of the "Login"-Part. I would love to have the possibility to define the ID or a DOM-Selector that Enpass should use for a specific field. That would help to alleviate this problem.
