Historize all fields
Hi Enpass Team,
currently, AFAIK, only the fields with type "password" are historized. But there is sometimes important informations in other type of fields that you may want to keep in case you need them. I think all fields should be historized (like Keepass).
Also, I would suggest an UX improvement on the way history is currently displayed. The current popover doesn't help to know the state of the different fields. I mean, with multiple password fields, it would be hard to know which version of field1 goes with a specific version of field2. I used to dev a web frontend for kdbx files. If you have time, have a look at how I implemented history navigation, I think it is a better experience:
Select the "Bank Web Account 1" password and navigate with the date on the bottom right.
Thx!
