June 15, 20188 yr Hello, I have display and focus issues. On the screenshot below, you can see that the top of the window is hidden by the title bar, so I can not click on the search bar. There is also a problem with the mouse, as you can see, the mouse is on the button "Install" but it is not highlighted, to click on it I have to put the mouse in the second half of the button. This problem appears throughout the application, I must always click on 60px below ... Thanks.
June 18, 20188 yr Hi @Emilien, Thanks for reporting this issue. I've forwarded this issue to the team to look into it. Cheers!
