June 16, 20188 yr Hello, I tested the beta enpass 6, which sounds great, but it would be even better if we could specify the rights on each password for each user who shares multiples vaults. For example on my vault "family" I would like to be able to indicate that for a specific password, only my wife session and my session are able to modify the information, and also for example, that we are the only ones able to see the password in clear but that everyone can make the autofill (even if there is a way to recover the password in clear with a trick for the others, it is not serious, the main thing is that the password is not displayed in an obvious way for childrens) Edited June 16, 20188 yr by Avogadro
June 23, 20188 yr Please consider implementing this suggestion. I think it would be great if one could add a secondary means of securing a specific folder or entry within a vault.
