May 19May 19 Hi,It seems I have too many identical passwords being detected and when I check some of them belongs to an SSO type of logins for different corporate sites. Is it possible to get these to be merge or something to remove them of being identified as 'Identical". Maybe a toggle option as its SSO password or something.
May 20May 20 What you’re seeing is expected behavior in many password management and security auditing systems. When multiple accounts use the same credentials — even across different corporate or SSO-integrated sites — they may still be flagged as “Identical Passwords” because the system detects password reuse rather than the authentication method behind it.For SSO-based applications:The sites may rely on a central identity provider (such as Azure AD, Okta, ADFS, etc.)Even though they are different portals, the same corporate credentials are being usedAs a result, the password audit identifies them as duplicatesAt the moment, there may not be a built-in option to automatically merge or exclude SSO-related entries from the “Identical Passwords” category. However, your suggestion about:an SSO-specific toggle,grouping linked SSO accounts,or excluding federated logins from duplicate-password detectionis a very valid enhancement idea and could improve reporting accuracy and reduce false-positive alerts.As a workaround, you may:verify whether the affected entries are indeed federated/SSO accounts,exclude them during manual review,or categorize them separately if your platform supports tagging or custom grouping.
