June 27, 20187 yr Hi, it seems that neither the shortcut or autofill functionality are working on Firefox for Linux. In Chrome/Opera it does work. What works in firefox is right-click and then select Enpass, but for me this is not very usefull since I am mostly a keyboard user.
July 3, 20187 yr Hey @mat We have tested this issue in our labs but unable to reproduce it. Please make sure that you're using the right shortcut command that you've set up in the extension settings. Please provide some more details so that we can investigate further. Which versions of OS, Enpass and Enpass extension are you using? Which Firefox version are you using? What shortcut have you set for Firefox extension? Are you facing this problem on any specific website? Thanks!
July 3, 20187 yr Author Hi, I just changed the shortcut from ctrl+: (i'm on azerty) to 'ctrl+,' and this works OK. It is however strange that ctrl+: does not work. Firefox: version 62 (developer edition, but also doesn't work on the regular edition) Enpass: 5.6.9 Extension: 5.5.2
July 4, 20187 yr Hey @mat Thanks for sharing the details. I've noted them down for the QA team to look into it. Cheers!
November 27, 20187 yr Hi, Same problem here : Linux Arch up to date Firefox 63.0.3 / Chrome Enpass 5.6.9 FF Extension 5.5.2 Edited November 27, 20187 yr by jdegreef
