Enpass 5.2.1.1/Ubuntu 16.04 - No TOTP or diceware?
I got super excited when I saw that Enpass now supports TOTP and diceware, but kinda confused why I only have those on Android (v5.2.0) and not with the Linux app (v5.2.1 from Ubuntu repo). I think after re-reading the post about Android using diceware, I was assuming that it was for all platforms but it looks like that's just Android for now? I'm still confused as to why I don't have the option to at least add a TOTP in the Linux app that it seems to show in the manual, all I have is Add Field and Reorder Field. Or do I manually just make a field labelled TOTP?
I ran
apt-get update && apt-get upgrade
several times and couldn't find any updated repo, is there something I'm missing here? Really excited to get this going!
Edited by 4oo4
Hi @4oo4,
Thanks for writing in. Currently TOTP support is available for Login categories only, but we have added its support for all categories (except Secure Note) in latest beta version and very soon we will roll out a stable one.
BTW,  you are using right command.
Cheers!
That makes perfect sense, I was trying to add a TOTP to something in a custom folder. Looking forward to seeing that rolled out!
Any word on when I can expect to see Diceware-generated passwords in the desktop versions? Really excited about that as well.
Cheers!
Hi @4oo4,
Thanks for writing in. I am glad to inform you that the support for Diceware-generated passwords has already been added in latest beta version.
Cheers!
