July 8, 20188 yr A few issues that I spotted: 1. Option to hide user name in list view, i. e. instead of showing two lines ("Amazon" + "user@amazon.com"), it should show only the title to increase visibility. 2. Existing password entries cannot be used to create a template. 3. Copying/moving entries between vaults isn't working, it doesn't show up in the destination vault - it shows the 2nd entry in "all vaults" view but it doesn't show up when I only display the destination vault. 4. Location of the database cannot be changed (I'm sure you are already aware of that). 5. Password strength indicator ("Very Poor" etc) should have an option to be turned off. Often, I can't use longer/better passwords because the website doesn't allow me so and I don't want to be reminded constantly. 6. Will one of the cloud services that you are going to add be OneDrive for Business? Thanks, you have done a terrific job with the version 6!
