July 9, 20188 yr Thanks for switching on the one drive sync integration. Just one question before i test this - i assume that Version 6 does not use the same sync files as version 5 ? In other words, if i configure V6 to sync with the same onedrive account as V5, V6 wont affect the V5 files already present ?
July 9, 20188 yr Hey @Nigel Flowers No, the data file from V6 won't affect the data previously created with the older version (V5). Instead, a new folder named Enpass6-beta will be created when you sync it to a cloud account. Please have a look at this post to know how to restore the Enpass 5 data to the latest version (V6). Cheers!
July 10, 20188 yr Hi there. I Also have the problem to use OneDrive. If i Click on OneDrive --> the link sets dropbox as URL As i see, OneDrive is not yet implemented: Page not found (404) Request Method: GET Request URL: https://auth.enpass.io/dropbox/?code=Md943c21a-336d-a52f-be5c-360009d76466 Using the URLconf defined in cloud_auth.urls, Django tried these URL patterns, in this order: ^admin/ ^dropbox/$ ^googledrive/$ ^box/$ The current path, onedrive/, didn't match any of these. You're seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard 404 page.
