July 27, 20188 yr Hi, My feedback/questions for the Enpass 6 beta for Windows. The UI is too little on my UHD monitor (3840x2160). Need to add option for high resolution display. Highlight the item count number as in Enpass 5 to make it more visible. I'd like import some backup data of Enpass 5 for test, but i'm unable to do it. Add option to change the hamburger menu in a classic menu bar. How do you use the TOTP field? For many services that I use I need to enter a One Time password via mobile app or physical digipass. Let's hope a French version will be up for the final stable version of Enpass 6. Can you add a function (if possible) for warn the user if the URL is https or http? Just put the url with http in red as with a weak password. Thank and continue the great work.
