August 5, 20188 yr I would like to change the name of the Vault, and maybe have different names in different computers, but the most important is to be able to change the name of the vault once its created or synced. Also, removing the Primary, and setting a new as a primary, so you can delete the one that is created by default if you allready have one created that you want to use as default.
