August 22, 20188 yr With Enpass 5.6, I can configure a system-wide hotkey to open the Enpass Helper, type a search term, then use arrow keys followed by the return key to copy a password. On the new beta version this doesn't work: There's no setting for a system-wide hotkey to open the helper After opening the helper by clicking the menu item, the search box doesn't always have keyboard focus (it does occasionally have focus. I haven't been able to reproduce reliably) Once I've typed a search term, I'm unable to use arrow keys to select a result - I have to click the tiny "info" button With the entry details open, again it's not possible to navigate with arrow keys or hit return to copy a password I hope this can be resolved soon. I've been waiting a very long time for multiple vaults, and now I have it this new issue is preventing me from fully switching to Enpass from 1Password (I currently use Enpass 5 for one of my vaults, and 1Password for two other Vaults). PS: It would be really nice if, when using an arrow key to open an entry, it highlighted the password automatically. On Enpass 5.6 nothing is highlighted and I typically need to hit the Down Key three or four times before Enter to copy the password. (I'm using the macOS version of the beta) Edited August 22, 20188 yr by abhibeckert
