September 5, 20188 yr Hi, since some days the Browser Extension for Google Chrome does not work any more (Chrome-Version 68.0.3440.106, Windows 7 Enterprise). When clicking the icon simply nothing happens. I already tried to re-install and clear cache etc. but the problem is still there. As the Autofill function for a password-manager is an essential function it would be perfect to get support to make it work again! Best Regards, Frank
September 5, 20188 yr Hi @callfrank, Sorry for the trouble you are going through. Please share some more info so that we can help you better. Which Enpass and Enpass extension version are you using? Are you using any antivirus or third-party security-related extension or proxy? Are you facing the same problem with other browsers (Firefox/Opera) too? Thanks for your co-operation.
September 10, 20188 yr Author Hi, after having installed the very new Chrome-Version ist works again! Thank you.
