September 9, 20188 yr Enpass 6 works a bit different than 5, since now it has at least two files in constant use, making Onedrive unable to operate correctly as long as Enpass is open: As I said, this doesn't work in Enpass 5, as any vault stored in Onedrive was only "used" when saving a new login and only in that moment, and there were no settings file in My Documents folder (any program should use %AppData% instead anyways. I don't want more folders in My Documents, please).
