September 11, 20188 yr Enpass 6 on macOS seems to use the discrete graphics card by default, and will not allow the system to switch to the built-in card while the system is running on battery power. This kills batteries, and means that I have to kill Enpass when I'm not running on mains power. Enpass 6 Beta (6.0.0 187)
September 12, 20188 yr hi @Eugéne, Thanks for reporting this issue. This issue has been fixed and you will get it in the next update due soon. Cheers!
