Faster access to TOTP
 Is it possible to create a new category for faster access to TOTP as on my picture. With a click would be possible to reach all TOTP codes, and it would help find TOTP codes faster on the job computer where I can not install Enpass.
  • 3 months later...
Definitely a great idea. Just bought Enpass and switched from Keepass / LastPass / Authy to just Enpass. Easier TOTP access would make Enpass a full authenticator not just a password manager
  • 2 weeks later...
Having a section inside the app seems like a lot of steps to get a code, I would love to see a widget like Authy. Or even better, auto-fill codes after logging in. I use Snap Swipe Drawer, with the Authy widget, and get get a code very quick. If I could do that with Enpass, I'd drop Authy in half a second :)
Edited by Pete
  • 2 weeks later...
On 9/19/2016 at 1:53 PM, Anshu kumar said:
Thanks for the suggestion @Arnas! It's a cool idea, I have noted your request in roadmap.
Cheers!
I love this feature, beside that if we have option to hide some character of email in tab TOTP. like : testenpass@gmail.com then in TOTP it should show te***ss@gmail.com
  • 1 month later...
Cheers!
How far are the plans/development for implementing this feature?
Hi @Kelvino,
Thanks for writing in. This feature has already been in the development phase but at the moment I can't assure you any ETA for this and only can say that it will be available in any of coming releases cycle.
Thanks for your co-operation!
