September 21, 20188 yr Hi. EnPass Linux application does not attach IM. Other QT5 application works fine. environment variables are set like below QT_AUTO_SCREEN_SCALE_FACTOR=1 QT_IM_MODULE=fcitx XMODIFIERS='@im=fcitx' XIM=fcitx also I tried to override some environment variable export QT_PLUGIN_PATH=/usr/lib/qt/plugins:"$enpassRoot/plugins" export QT_QPA_PLATFORM_PLUGIN_PATH=$enpassRoot/plugins/platforms But not affected. OS is archlinux. installed from aur.
July 13, 20197 yr On 9/21/2018 at 2:09 PM, Munsen said: Hi. EnPass Linux application does not attach IM. Other QT5 application works fine. environment variables are set like below QT_AUTO_SCREEN_SCALE_FACTOR=1 QT_IM_MODULE=fcitx XMODIFIERS='@im=fcitx' XIM=fcitx also I tried to override some environment variable export QT_PLUGIN_PATH=/usr/lib/qt/plugins:"$enpassRoot/plugins" export QT_QPA_PLATFORM_PLUGIN_PATH=$enpassRoot/plugins/platforms But not affected. OS is archlinux. installed from aur. Hello, are you solve this problem?
