September 21, 20188 yr I'm running Enpass Beta 6.0.0 (187) on macOS High Sierra 10.13.6 (17G65). Are there templates we can use to create new custom icons & where are the icons stored? I added a few icons that I would like to remove from the vault.
September 24, 20188 yr Hi @v3ritas, Thanks for writing in. Currently, it's not possible. However, removing the custom icon is already in our roadmap and will be available in the subsequent beta update. Cheers!
