September 24, 20188 yr I just installed Enpass 6 on a fresh Windows 10 N install and I get these errors when I try to start it: --------------------------- Enpass6.exe - System Error --------------------------- The code execution cannot proceed because MF.dll was not found. Reinstalling the program may fix this problem. --------------------------- OK --------------------------- --------------------------- Enpass6.exe - System Error --------------------------- The code execution cannot proceed because MFPlat.DLL was not found. Reinstalling the program may fix this problem. --------------------------- OK --------------------------- --------------------------- Enpass6.exe - System Error --------------------------- The code execution cannot proceed because EVR.dll was not found. Reinstalling the program may fix this problem. --------------------------- OK --------------------------- --------------------------- Enpass6.exe - System Error --------------------------- The code execution cannot proceed because MFReadWrite.dll was not found. Reinstalling the program may fix this problem. --------------------------- OK --------------------------- Edit: turns out these are part of the Media Feature Pack (which is missing from the N edition), is there a reason why Enpass would require this? Edited September 24, 20188 yr by Patrik
September 25, 20188 yr Hi @Patrik Sorry for the trouble you're going through. I've noted down this issue in the bug tracker and notified the dev team to look into it. Till then we request you to please co-operate with us.
December 4, 20187 yr Hey guys, Sorry for the inconvenience caused to you. This issue has been fixed and will be available in the next update. Till then I request you to please co-operate with us.
