September 26, 20188 yr Hello, I've tried to import an Enpass 5.6.9 backup file in Enpass 6.00 (72). Some items are missing after restore. I've 515 items in Enpass 5 and 492 in Enpass 6 after restore. Thanks for help. Regards,
October 6, 20188 yr Hi @Ludo Sorry for the trouble you are going through. Could you please try updating the app to the latest beta version and now try to import Enpass 5 data and let me know if the problem persists. Thanks for your co-operation.
October 9, 20188 yr Author Hello, After upgrading to the latest version 6.0.0 (149) and change language from French to English before creating a backup from Enpass 5.6.9, all works fine. I've exactly the same number of item in each Enpass. Thanks.
October 9, 20188 yr Have you checked that no information is missing inside the elements? For me there are almost all passwords missing.
October 9, 20188 yr Author Hi, I can't check all, however, I've checked several of them and passwords were there. Thanks
