Not able to reset App on Device
Hi
I try  to"reset" the app on my device. The app don't accept my Master Password. I'am sure that it is correct, but ok.
So i try to uninstall the app. Before uninstalling i deleted the cache and data under Settings / App/... .
The I unistalled the app. But after installing from the Store i will be asked for the Master password.
Tried a couple of things. Looking for a folder on the device. Cleared data and cache, uninstalled, rebooted...
Nothing works. There is noway to start from the scratch (may be that i can make a "hard" reset for the device....).
Any idea how to get rid of the Master Password nightmare?????
Thank you in advance
HaPe
  • 5 weeks later...
Hey @BrinaLowe
Please follow these troubleshooting steps and let me know if the problem persists:
  • Quit Enpass (If running).
  • Go to Device Settings --> Backup & Reset --> Disable Automatic restore.
  • Goto Settings--> Manage Applications--> Click Enpass--> Clear cache and data
  • Now open Enpass --> It will prompt you a Welcome Screen.
Hope this helps!
