October 4, 20188 yr Question about keyfile support. I'm trying out the beta builds for Linux, Android and Windows traditional. It appears that the keyfile must have a .enpasskey extension. I always felt that keyfile authentication helped with security because it can be disguised as a random file. Like a photo, or a powerpoint demonstration, etc. By using the .enpasskey extension, its clear to anyone what that file is used for. Am I missing something? I can't seem to use anything other than a .enpasskey file. I don't want to come off as ungrateful though. I do thank you for your product. Been using it for at least a couple years now. Just wondering if there are plans to support any file type.
