October 23, 20188 yr Hi, Since installing the enpass 6 beta I have been running into cases where chrome locks up on launch for over 60 seconds. I have since discovered this is a cumulative effect of 3 settings: OneDrive Being allowed to sync all of Documents: Enpass 6 storing its tmp directory in documents: C:\Users\<user>\OneDrive\Documents\Enpass6-Beta\.sync The Enpass Password Manager extension for Chrome using the .sync directory on launch. The fix is pretty simple in Microsoft OneDrive Settings -> Account -> Choose Folders unselect the enpass directory Since most of my settings were default, I expect others are having the same issue and are not sure how to fix it, hopefully this helps.
