November 14, 20188 yr Hi, my mail provider switched to a two step login process. Frist you have enter your mail address then click on a 'Continue' button (or hit Enter or Tab) and then fill-in the password. Similar to the Google login. I didn't found a solution to tell Enpass the new way how to login. In KeePass(XC) you can create a kind of workflow how to login: {USERNAME}{TAB}{PASSWORD}{ENTER} Has Enpass a similar possibility? Example page: login.mailbox.org Env: Fedora 29 Enpass 5.6.9 UPDATE: They switch back to one page login process, but the general question still remains - may for the further or other sites Edited November 15, 20188 yr by nech+arHU
