December 28, 20187 yr Hi guys, since the upgrade to Enpass 6 I can no longer launch enpass from the application menu in Kubuntu 18.04. The sync cannot be activated as well because of the error messages (s. attachment). It worked flawlessly before. I have purged enpass completely as well once but the issue remains. I can launch the application only from /opt/enpass/ but if I want to add the app to my task bar and close the app it won't launch afterwards. Please help ! Greetings Marvin
December 28, 20187 yr I also have problems launching enpass after the update to 6. On my desktop (linux mint) I get no reaction after giving the command (alt F2, enpass) 'enpass'. The icon is visible but does not react with a gui to sign in? Hope someone can help me quick. I cannot sign in, in most applications. regards, Ed
December 28, 20187 yr Hi @MarvinD Please try to run command "xdg-open enpassauth://onedrive". If it fails to launch Enpass than protocol handlers are not yet updated. A reboot of system should work. Thanks.
December 28, 20187 yr Hi, I tried your suggestion. Here is the response: ed@laptop ~ $ xdg-open enpassauth://onedrive /opt/enpass/Enpass: error while loading shared libraries: libcurl.so.4: cannot open shared object file: No such file or directory ed@laptop ~ $ Does that mean libcurl.so.4 is missing? Hope to hear from you, thanks in advance, regards Ed
December 29, 20187 yr Hi @EdvanderMark, It seems you are using Min 18. Enpass 6 requires libcurl.so.4 for internet operations and we couldn't find any package that provides it under Mint 18. So, minimum supported Mint OS is 19. Sorry, but this is not something we can fix from our side without breaking things on new os versions.
December 29, 20187 yr Okay that’s clear. So I should upgrade to 19 or reinstall enpass 5. Is their an enpass 5 deb-file available? Thanks in advance, regards Ed.
December 29, 20187 yr @EdvanderMark One of Enpass user @WA3UFN was able to run it with Mint 18. Please refer this thread.
December 29, 20187 yr Hi, this afternoon I upgraded Linux Mint 18.3 to Linux Mint 19. And!, I was able to restore the backup. So for me it's solved. Now I am checking if the sync in the cloud works again. As soon that's ready I am pleased. Because I found and find Enpass very user friendly! Thanks for the support, regards Ed van der Mark
December 30, 20187 yr Now everything is working as it should. Enpass is a very nice application for me, thanks very much for the support, kind regards Ed
December 30, 20187 yr Author Unfortunately I have this output: Why did it work previously then ? $ sudo apt-get install curl libcurl3 Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig curl ist schon die neueste Version (7.58.0-2ubuntu3.5). Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass Sie eine unmögliche Situation angefordert haben oder, wenn Sie die Unstable-Distribution verwenden, dass einige erforderliche Pakete noch nicht erstellt wurden oder Incoming noch nicht verlassen haben. Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen: Die folgenden Pakete haben unerfüllte Abhängigkeiten: libcurl3 : Kollidiert mit: libcurl4 aber 7.58.0-2ubuntu3.5 soll installiert werden libcurl4 : Kollidiert mit: libcurl3 aber 7.58.0-2ubuntu2 soll installiert werden E: Fehler: Unterbrechungen durch pkgProblemResolver::Resolve hervorgerufen; dies könnte durch zurückgehaltene Pakete verursacht worden sein.
January 6, 20197 yr Author Guys is this still being checked ? I need your help... It worked before....
January 20, 20197 yr On 12/29/2018 at 9:42 AM, Vinod Kumar said: @EdvanderMark One of Enpass user @WA3UFN was able to run it with Mint 18. Please refer this thread. @VinodKumar just for the record and perhaps other users: I am using Mint 18.3 and had the same problem that Enpass would not launch. I followed your link to WA3UFN, where you recommend sudo apt-get install curl libcurl3 I tried it, and it worked !! Thanks Edited January 20, 20197 yr by Klaas Vaak
