[Solved] No Enpass icon in Top Panel - Ubuntu 18.04
I have installed enpass (version 6.0.0.230) and icon does not appear in top bar. I can see the menu (display assistant, restore, quit) if i click where is supposed to be the icon.
What is curious is that enpass-beta (version 6.0.0.149) present also in the repository's provided for Ubuntu displays the icon..?!
If someone has a solution... Thx.
Edited by Fred
Launch result Enpass in a terminal:
/opt/enpass/Enpass
QQmlComponent: Created graphical object was not placed in the graphics scene.
QSystemTrayIcon::setVisible: No Icon set
I solved my problem.
In fact, I had a usage of installing my icon themes in $HOME/.local/share/icons. I think Enpass should not/no longer be designed to fetch its icons from this directory.
I have restored all of my icon packs in $HOME/.icons and since then, Enpass has displayed its icon in the top bar. :)
Sorry for the inconvenience. This post may be useful to others.
