No recursive search box
Hello,
I notice that the search box only returns the occurrences found in the main title part and not in the other parts such as notes, url, etc. ..?!
It worked as expected in version 5.6.9; Could you make sure to resume this behavior in the new version of Enpass.
Thank you.
Yes please! I really need to search by login ID. This is the only issue I have with the new release which is otherwise great.
Hi Vinod,
I did not see the little arrow in the lens.
By default, the box checked is on Title while I waited on "Fields"...
If I understand correctly, the box "Fields" includes everything except the search on passwords.
Perhaps some users would expect to be able to check an "All" box that also includes passwords.
An idea like that ... :-)
Thx.
