January 5, 20197 yr For some reason, after the new update, all my emails that I send from my gmail app on my phone have an attachment with the name "untitled attachment XXXXX.enpasscard" where XXXXX is a 5 digit number. Can anyone shed some light on this so I can fix it? Thanks
May 2, 20197 yr Hi All, That's really strange. We need some more information so that we can check what could be the possible reason for this unexpected behavior. Device and Android version. Enpass version. Does the issue occur when you share an item from Enpass app or send a new email from the Gmail app? Have you created a Template or Signature for email that contains any .enpasscard file? Does the issue occur every time you send an email?
May 13, 20197 yr Hi, I've got the same issue here. Here are the details: Android 8.0.0 @ Asus_Z017D (ZenFone 3), Enpass 6.0.6.200. I've been sending the e-mail as a reply via the Gmail app. Yes, there was a signature attached but has not contained any files in it and I didn't intend on attaching an enpass file. As for now, this is the only instance of this behavior. EDIT: I've just checked: It happens at least since the beginning of April. EDIT again: It seems, that the attachments are visible with MS Outlook (I haven't got any other e-mail app, so I can't check it), and I've found them on e-mails back up to June 2017! Guys, there's something really wrong there Cheers, Rafał Edited May 13, 20197 yr by filozof
May 14, 20197 yr An update there. I've installed Mozilla Thunderbird, to test the issue. Thunderbird does not show these attachments. Web-based email clients do not show them either. So I've done some more testing. The issue is with MS Outlook and Enpass Password Manager UWP. I've uninstalled Enpass password manager and the attachments had shown up as ordinary txt files, containing the plain text of html message (exact copy without formatting). Then I've installed Enpass win32 app, the issue doesn't occur. MS Outlook shows the attachments as txt files. I think now, that there's a problem with file associations, that Enpass UWP or Outlook makes for text files/attachments. EDIT: I've shouldn't jump to the conclusion so fast. First I've restarted my computer, the attachments were shown as text files but after a while those files name extensions changes form txt to enpasscard. So it seems is not associated with Enpass app, but it's Windows issue. Cheers, Rafał Edited May 14, 20197 yr by filozof
June 8, 20197 yr Hi I have just noticed the same problem when sending email from iPhone (IOS 12.2). When the mail is viewed in Outlook the unusual attachment untitled attachment XXXXX.enpasscard appears, where xxxxx is a five digit number. Could you please advise? Thanks
June 11, 20197 yr Hi @TomTom. Sorry for the trouble you are going through. I have noted down this issue and forwarded to the QA team to look into it. Meanwhile please let me know which Enpass version are you using so that we can proceed further. Thanks for your co-operation.
October 29, 20197 yr Its is the same at my Samsung A50, latest Updates and Enpass 6.2.1.257 ... are there any fixes? Regards
January 8, 20206 yr I've just had this too. I drafted an email in Thunderbird, edited the draft on my Android phone, and then updated the draft on Thunderbird again and this attachment was then present. I've repreated this action and it does seem that the act of editing the draft on the phone is causing the attachment to appear. If I just save the draft, close it and reopen it on Thunderbird on my PC, the attachment does not appear. The file in my case was called "nsmail.enpasscard". In Thunderbird it appears in the attachment box as "Attached Message Part", with the enpass logo preceding it. In my case, hovering over the attachment showed the path "file:///C:/Users/Rob/AppData/Local/Temp/nsmail.enpasscard" I opened this with notepad++ and the contents appear to be the email draft itself. The mail app on my phone is the standard email app on my Galaxy S8, v6.1.01.0. Enpass version on Android is 6.3.4.298 Rob Edited January 8, 20206 yr by RobS Fix typos
