Restriction on customized templates?
Hi - I'm running Enpass 6.0.1 (239) on Ubuntu 18.0.4.
I have created 12 customized templates, and I can select from any of these when adding a new item. Great! However, when I go to "Settings > Customize > Templates", I can only see 10 of the templates in the Existing Custom Templates pane. This means I can't edit, or delete the other, non-displayed templates. Is there a restriction on the number of templates that can be created, or is it a bug, or am I missing something fundamental?
Many thanks
The problem appears to be with the scroll bar in the pane. It could be local to my machine, so please ignore this post.
