January 18, 20197 yr Since some time (21. Dec) Enpass under Linux (Ubuntu 18.04) does no longer sync its data to google drive. I am using version 6.0.1. When i do a "Tools -> Sync now" i dont see any modificatiton data change on my google drive under folder "Enpass" with file "sync_default.walletx". The file keeps to have a modification time of 21.12.2018. I already tried to disconnect / reconnect sync from Enpas linux client without any effect. Kind regards
January 21, 20197 yr Author BTW, there is no newer version for linux available than 6.0.1. On Windows we have 6.0.2 ....
January 22, 20197 yr Hey @hcw70, Skipping this thread was just an oversight. Sorry for that. I would like to share that Enpass 6 now syncs the Enpass data into the designated App folder on Google Drive. To view Enpass file please follow these steps: Open Google Drive in any browser --> Click on Setting icon --> Click on Settings --> Manage Apps --> Enpass. To check sync functionality, do some sample change like mark any item to favorite, add a new item in any one device. Now check does the changes are reflected in other devices? Thanks for your co-operation.
