January 23, 20197 yr It would be nice if there were a way of using the assistant to autofill (or at least slightly auto) in desktop applications. Currently the only thing the assistant can do is open a browser, or show the desktop app slightly smaller, which isn't very useful when the browser extension already has a keyboard shortcut. As the assistant can be navigated with the keyboard fairly well, it would be useful to be able to copy attributes quickly. eg doing `ctrl + c` would copy the password of the selected element, `ctrl + b` copy the username, and `ctrl + t` copy the TOTP item (Yes, these are the same shortcuts as KeePass uses (KeePassXC, anyway). This is probably much easier to implement than anything more global, and could be used with many more applications, especially if the assistant minimized itself on these keyboard shortcuts, and then remembered where it was when the assistant was triggered again.
March 7, 20197 yr Hello, I totally agree here, i'm using a lof of application and it's always a pain to be forced to use the mice when a keyboard shortcut can do the trick. We can invoke the enpass windows from anywhere with a shortcut but can't copy the password with a shortcut.
