February 4, 20197 yr Hi, I've just imported logins from Roboform (v8.5.3 running on Mac) using Print List>Logins, then saving the html file. This works fine except it doesn't import the URLs. Logins are correctly created within enpass without any website associated, so the 'Launch URL' option is disabled I've tried to play with the html file but haven't found what is missing. I've attached a file with just one entry, this has to be renamed to Roboform login.html (since only images attachments are allowed) For some reason, a <wbr> is added but it seems this doesn't break the logic since username and password are correctly created. hope you can help Edited February 4, 20197 yr by _olive_ adding the file
February 5, 20197 yr Hi @_olive_, Thanks for reporting the issue. We have noted it down. Fix will be available soon.
