February 19, 20197 yr Atm, access to multiple vaults works with the master password of the first vault. This prevents different users with different vaults can use enpass on one PC. In addition I think it's a security issue, because the master password of other vaults are saved in Enpass / in the first vault. A master password should never be saved anywhere! So it would be great, if access to a vault should only be possible with each vault's master password. Not with the master password of another vault. For me it's not importent opening multiple vaults at the same time. I only want to manage/using them separatly with one Enpass installation or within the web browser. Edited February 19, 20197 yr by AMK
March 7, 20197 yr I fully support this request. Having two or more independent vaults is a major point for Enpass (in theory). So far I can use any other PW-Manager (Reasons explained by AMK already)
November 11, 20197 yr On 11/9/2019 at 12:50 PM, IT'ler said: I agree too. It's a security issue. Erm, having multiple users using the same user account seems to be the real security issue here. That's not how a multi user system is supposed to work.
