How does iCloud sync work?
Sorry if I'm posting this in the wrong area.
I sync Enpass 6 between my iPhone and two macs.  After having some problems with syncing after upgrading from version 5, I cleared out everything in the iCloud drive/Enpass folder. However when I went to re-sync, Enpass was still somehow pulling information from iCloud, which was the old information.  I had to check the box to delete everything from iCloud, restored from a backup, and re-setup sync successfully and it works well now.
My question is, how does syncing with iCloud work?  I see there are files under ~/Library/Containers/in.sinew.Enpass-Desktop/ however this is being stored on my local machine. I've searched the ~/Library/Mobile Documents/ directories and unless they are named differently, I can't find any trace of my vault or associating files.
So what is being synced across iCloud and what is the location?
Thanks much!
