March 18, 20197 yr Hi together, actually I have the following problem: After connecting with the webdav folder (the permissions are correct) I get the error message "sync error 908417" The problem arises both when I try it in the local network, as well as a dynIP (port forwarding in the router is active - otherwise I would not have been able to connect) Anyone can help?
March 19, 20197 yr Hey @crazyheinke, Sorry for the trouble you are going through. The reason behind getting the error code 908417 is that the server is not responding correctly to WebDAV quries made by Enpass. If possible, please share the demo account of your WebDAV via PM so that we can investigate it further. Thanks for your co-operation.
September 1, 20197 yr Hello! I'm also having this problem... Is there any solution for this? Edited September 1, 20197 yr by Pendente
September 2, 20197 yr Hey @Pendente, We are sorry for the inconvenience. We’ve been working hard to improve WebDAV sync functionality, but it’s a big challenge to cover all the WebDAV configuration. We request you to please share the demo account of your WebDAV via PM so that we can check where the problem could be. Thanks for your co-operation.
