Focus follows mouse breaks Enpass browser integration
Hello,
I use Enpass under Ubuntu 18.04 with the sway window manager (=i3 for wayland) and 'focus follows mouse'
and the Enpass window keeps on disappearing on me when I move the mouse.
This is annoying when lookup up passwords but disastrous when creating new ones, since that window appears at the top right corner and I
can't get the mouse there without it disappearing.
This behavior stops when I disable focus_follows_mouse but that's just an annoying work around.
Can't find anything in the options to stop this behavior.
  • 4 weeks later...
Sincere apology for the late reply. We have already introduced the Docked moded feature, especially for the Tiling Window Manager, to deal with focus related issues. With this, you can stick the Enpass Assistant on the screen, and it won’t disappear when you click outside it. You can enable it from Enpass General settings under the Behavior section. Also, once the Enpass Assistant is opened, you can use the Keyboard shortcut Shift+Ctrl+ D to stick it on the screen.
