Field order
Under Windows 10 Desktop it would be nice to rearrange the field order of the entry. Actually new fields where added only bevor teh NOTE field.
Hi Chris,
The requested feature of field reordering is already in available in Enapss for traditional Windows version. Check out the link for more details: https://www.enpass.io/docs/desktop-mac/customize.html#re-arranging-fields
But if you're talking about the same feautre in Enpass UWP app, then it's already in our road-map and you will get it soon.
Hi Chris,
it's already possible. Give a look at -> https://www.enpass.io/docs/desktop-windows/customize.html#re-arranging-fields
it's in the new version a little different and you have to first on "Field" and then on "Reorder Fields", but then you can order it as you want it.
Unbenannt0.PNG.0a6ad783ecb176b1b715c9a28--> Unbenannt.PNG.5af0aed80c57c8e070db38e501
I hope, I have understand your problem correctly.
Edited by edenhaus
Screenshot wasn't attach to the post. I hope this time.
