April 22, 20197 yr Using enpass with windows 10 and chrome doesn't work. After installing the extension for chrome I can't connect the enpass app with the enpass extension for chrome. I always get the error "Enpass assistent can't connect to the Enpass-App" (Enpass-Assistent kann keine Verbindung zur Enpass-App herstellen). On the same windows 10 system enpass is working fine with edge. Any hint what could be the reason for this behaviour? Best regards
June 12, 20197 yr I have the same problem! Only Edge works fine. Firefox extension has the same error. My configuration is Win 10 1809 | Enpass traditional 32bit 6.1 | Extension 6.02
June 12, 20197 yr Same issue here. @workaholic63 Can you confirm that you are using the traditional version of Enpass too? Maybe it's an issue with that (because the bug doesn't seem to get a lot of attention) Edit: Just tested the Micro$oft store version. Same behaviour. Enpass 6.1.0 (407) x32 traditional | Win 10 Pro 1809 | Extension 6.02 Edited June 12, 20197 yr by ng1905 Tested possible work around
June 13, 20197 yr Same problem. Using MacOs Mojave 10.14.5 Enpass 6.1.0(390) In FireFox 67.0.2 (64bits) also Chrome Versión 74.0.3729.169 (Build oficial) (64 bits). It was working with FireFox, but I don't know when it stopped working.
June 14, 20196 yr Hi guys, Sorry for the trouble you are going through. Please drop us an Email at support@enpass.io along with these details so that I can help you better. On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Are you facing the same problem with other browsers too? Are you using any Antivirus or third-party security-related extension? Also, please share the logs of Enpass app and Extension? It will be invaluable to our technical team to understand and address the issue. You can enable the logs from the app by following these steps: For Enpass app: Go to Settings > Browser > Enable logs. For Extension: Go to Enpass extension's options page > Enable logs. Quit the app. Even from the System Tray or Menu Bar. Open the app. Restart the browser. Copy the logs of Enpass app and extension. Thanks for your co-operation.
June 14, 20196 yr It's working now, After several attempt, I gave up, Next day I try again, it start working, I guess, restarting the computer could be the solution at least for me. Thanks.
