May 17, 20197 yr Can someone produce a "side load" version of EDGE Extension. As I understand it CHROME/FIREFOX extensions should be easily modified to work and side loaded into EDGE. Orr if someone already has please provide the link. Thanks
May 19, 20197 yr On 5/17/2019 at 5:49 PM, twos50 said: Can someone produce a "side load" version of EDGE Extension. As I understand it CHROME/FIREFOX extensions should be easily modified to work and side loaded into EDGE. Orr if someone already has please provide the link. Thanks https://www.enpass.io/downloads/ Choose the tab "extensions" Edited May 19, 20197 yr by Tuinpad
May 20, 20197 yr Author Tuinpad how would you "side load" the edge extension. I'm looking for an edge extension package to download to install without the use of the Microsoft store.
