May 24, 20197 yr Hi, I have a problem with autofill on Chromebook. I'm using Ethernet via ICY-BOX Dockingstation at my chromebook. The connection between App and Extension only works if WLAN is connected and Ethernet is disconnected. If both (WLAN and Ethernet) are connected it don't work. Without an networkconnection it's don't work also. The version-numbers: Chrome OS: 75.0.3770.24 Enpass-App: 6.0.8.215 Extension: 6.0.2
May 27, 20197 yr Hey @Tsoy, Sorry for the trouble you are going through. I have noted down this issue in the bug tracker and notified the dev team to look into it. Till then please co-operate with us.
