May 29, 20197 yr It fails in that nothing gets saved. I have tried to save both as .txt and .csv files, I give it a name, it gives the impression that the file has been saved, yet when I go into the folder specified (yes I checked it's the correct folder) there's nothing there!
May 29, 20197 yr Author Update: The failure is occurring when using a computer running Linux Mint 19. I've just booted up my Windows 10 laptop, and exported from Enpass on there without any problem. Failure on the Linux computer is not solved, but at least I have a workaround to get the exported file.
