June 5, 20197 yr Hi there Can anyone assist. Ive installed the correcrt extensions for chrome here https://www.enpass.io/downloads/ But it isnt autofilling. I suspect and i maybe wrong but chrome has its own filling service. Must i disable that so Empass works? or is there something else im not doing?
June 5, 20197 yr For me it has always worked correctly, have you tried the usual of restarting the browser/computer? Plus did you have to authorize the browser?
June 5, 20197 yr Author 1 hour ago, Dentonthebear said: For me it has always worked correctly, have you tried the usual of restarting the browser/computer? Plus did you have to authorize the browser? I have restarted the machine many times. Authorise the browser? Not sure actually. How do i force this step?
June 5, 20197 yr 4 minutes ago, Grant De Sousa said: I have restarted the machine many times. Authorise the browser? Not sure actually. How do i force this step? Have a go at this: https://www.enpass.io/docs/manual-desktop/browser_ext_pair.html
June 5, 20197 yr Author 11 minutes ago, Dentonthebear said: Have a go at this: https://www.enpass.io/docs/manual-desktop/browser_ext_pair.html Ye it seems that the browser is authorised. The plugibn icon is there and 'works" Im just trying to get it too auto fill passwords for websites?
June 5, 20197 yr 55 minutes ago, Grant De Sousa said: Ye it seems that the browser is authorised. The plugibn icon is there and 'works" Im just trying to get it too auto fill passwords for websites? Well I have exhausted the help I can give you, I suggest you post the following so the Enpass crew can help you better: Version of Enpass installed Version of Chrome installed Version of Enpass extension installed
