June 23, 20197 yr Appreciate that Enpass is first and foremost a password keeper and that there are lots of options for keyboards but can you consider adding the following options for Enpass Keyboard? Disable haptic feedback Allow autofill of TOTP after username/password without re-authenticating within a certain time period. Dark Theme Height Adjustment Number Row Long press for symbols. Many Thanks,
June 24, 20197 yr Hi @gigasmurfz, Thanks for your suggestion. I have noted it down and forwarded to the concerned desk for further consideration. Thanks!
