June 23, 20197 yr Hello, The version 6.0.2 of the Enpass Extension for Chromium does not work with the actual version of the Brave Browser on OSX (Version 0.65.121 Chromium: 75.0.3770.100 (Official Build) (64-bit)). After activating, it shows up with a large red space in the background and seems not to respond to any user interactions (visible response). Looks to me as if the extension cannot handle high resolution displays, but i could be wrong. Does anyone know how to fix this? Does someone else have the same problem?
June 24, 20197 yr Hi @MvDevNullNet, Sorry for the trouble you are going through. Our dev team is already working on this issue and hopefully a fix will be rolled out soon. Till then I request you to please co-operate with us.
July 29, 20197 yr I have a very similar issue with the Chrome extension on OSX 10.13.6 High Sierra (MacBook Pro). I see this red area when I move from my laptop screen to my thunderbolt display with higher resolution. I have a different problem when moving from the thunderbolt display to my lower resolution laptop screen in that the Enpass window is overly large. It seems that the Enpass plugin isn't adjusting for any (transient) change in screen resolution. I've found that killing and restarting Enpass fixes the resolution issue - but it's a pain as a work-around.
July 30, 20197 yr I have the same problem, the extension is always not usable https://imgur.com/a/DMcgsOm using Chrome Version 75.0.3770.142 (Official Build) (64-bit) on Mac MacBook Pro Sierra 10.12.6
August 1, 20197 yr Hi @Katniss We are sorry for the trouble you are going through. Our Dev team is already working on this issue and hopefully a fix will be available soon. Till then I request you to please co-operate with us.
August 31, 20197 yr hi i dont know if my problem is same as other but i cant figure out whats is problem. my browser gone RED, but i mean is like whole browser screen have red filter. absolutely unusable to use it now.when i open youtube whole site flickering red blue, like if it was on 3D of some sort
September 2, 20197 yr Hey @jozefsan, Sorry for the trouble you are going through. Please share some more info so that we can check further. Which macOS and Enpass version are you using? Are you using the multi-monitor system? If yes, please share the screen resolution of both monitors. Are you facing this problem in any specific condition or frequently. Thanks for your co-operation.
September 7, 20197 yr Hi i have the same issue, on my mac https://imgur.com/a/yUE7BvR Google Chrome is up to date Version 76.0.3809.132 (Official Build) (64-bit) Mac os X Mojave 10.14.6 EnPass: 6.1.3 (420) Chrome En pass Extension: 6.0.2 It looks changing to multi-monitor system to a single monitor, was causing the issue. Monitor was 14" 1920 x 1200 current resolution on my mac 15" 2018 - Intel UHD Graphics 630 1536 MB After a reboot with one monitor (no multi monitor) everything was fine ! Edited September 7, 20197 yr by regis
September 19, 20197 yr Hi, same issue running Firefox on my Mac. OSX 10.14.6 Firefox 68.0Enpass Password Manager extension 6.0.2 last updated May 27, 2019 Problem: Enpass always shows red background and is not usable since 3 weeks Cheers, Manfred Edited September 19, 20197 yr by mwalser
September 21, 20197 yr On 9/7/2019 at 11:47 PM, regis said: Hi i have the same issue, on my mac https://imgur.com/a/yUE7BvR Google Chrome is up to date Version 76.0.3809.132 (Official Build) (64-bit) Mac os X Mojave 10.14.6 EnPass: 6.1.3 (420) Chrome En pass Extension: 6.0.2 It looks changing to multi-monitor system to a single monitor, was causing the issue. Monitor was 14" 1920 x 1200 current resolution on my mac 15" 2018 - Intel UHD Graphics 630 1536 MB After a reboot with one monitor (no multi monitor) everything was fine ! Does anyone know how to fix this? With the red background, the plugin is not usable.
October 5, 20197 yr June, July, August, September, October Same problem as 5 month ago and no fix. Can you tell me on what kind of problem do you working on? The extension is broken! The problem happens when we use only the macbook screen. With connected 2nd and 3rd external display the extenstion is working without a problem. But after switch back to single dispaly and reboot of chrome or reinstall of extension problem is still there
October 30, 20197 yr On 9/2/2019 at 11:17 AM, Anshu kumar said: Hey @jozefsan, Sorry for the trouble you are going through. Please share some more info so that we can check further. Which macOS and Enpass version are you using? Are you using the multi-monitor system? If yes, please share the screen resolution of both monitors. Are you facing this problem in any specific condition or frequently. Thanks for your co-operation. Problem on my mac appears every time i switch from three displays to mac single display use. After restart of Chrome and enpass The extension will appear without any problems. But this is not so suitable in practice.
June 15, 20206 yr Same problem here. It worked for months but out of the sudden enpass plugin behaves strange (red backgrund problem). Brave: 1.9.80 Mac OS: 10.15.05
June 16, 20206 yr Hey @lfalkenburg Welcome to the forum and sorry for the trouble. Our Dev team is already working on this issue and hopefully a fix will be available in the future update. Till then I request you to please co-operate with us. Thanks for the co-operation.
