June 24, 20197 yr The link to the Chrome extension on your website ( https://chrome.google.com/webstore/detail/enpass-password-manager/kmcfomidfpdkfieipokbalgegidffkal ) is 404, and I can't find it by searching the store either:
June 25, 20197 yr 6 hours ago, Sojib said: I have the same issue Ditto. Same here. Fresh chrome install and went to get the extension. Does not exist.
June 25, 20197 yr Same here, fresh install of a Chromium browser (Epic browser). Can't be found with regular Chrome either.
June 25, 20197 yr Hi guys, We are having some temporary technical issues with the Enpass extension for Chrome browser. Our team is working to fix the problem. We apologize for the inconvenience caused. Your patience is appreciated. Thanks
August 14, 20197 yr Hi @Palich Thanks for writing in. You can download the previous version of Enpass extension from this link. Hope this helps!
